jonnyb1985
- Nov 28, 2011
- 16
- 0
Hi everyone!
I've just moved into a house and for aesthetic purpose, I want to chase a load of the conduit/trunking that is mounted on the walls into the plaster. I've no problem with the work itself, per se: got my oval trunking, know the circuit, etc. My problem is with the regulations.
Looking at the paperwork for the house, I've got the electrical installation certificate from 2007. My major issue is that it appears that my circuits upstairs are not RCD protected for some reason (I guess the regs were different then - certificate indicated BS7671 Part 2 as amended to 2002 with no departures).
Because the plaster is obviously not 50mm deep and because I wouldn't think I'm competent to install the earthed shielding, I think (though I'd appreciate being corrected!) that I would be disallowed from burying the cable in the plaster in this way even if it is in the safe zones. My question is really what to do next in practical terms - I'm not sure I can chase 50 mm into the brickwork beneath the plaster (though will if I have to!). Can/Should I get an RCD installed for the upstairs circuits? Is it going to cost me an arm and a leg (so I'm prepared for the quotes!)
Cheers,
Jon
Cheers,
Jon
