- Mar 28, 2008
- 14,663
- 1,364
wont comply with 314.1 (i) (iii)Could go 63amp or 80 amp and cover all board since the cost is not much more??
No - it's a like for like change. anyone can do itFor a housing association, All bonding in place 10mm to water and 10mm to gas ( i was surprised ), another question. If i replace the faceplate to the cooker, but don't move it does this need RCD Protection???
Sounds like you've got a Hobsons choice. If its your name on the cert, then its you who could go to jail which leaves 3 options, walk, chance an illegal installation, or absorb the cost of the RCD yourself. Don't suppose there's any other way of clawing back a few pounds by using cheaper gear / bulk purchase materials? Cable has dropped in price so maybe some money there? Other than that I think you're just going to have to stand your ground and insist the job is to standard.So yes they are being Awkward so and so's....
he lives in scotland.... it would be cheaper for him to pay more and get them locally!But Go in, In person
Quite correct there Mr vet!No - it's a like for like change. anyone can do itWhat if I wanted all my sockets in chrome? It's perfectly legal for me to do so.
Even (AFAIK) in a SL
Not even Midlands!!!no, south. none in the norththeir website says
'TLC have 23 Branches Nationwide.'
- 23 of them in the south!
if you add to an existing, what you add has to be to new regs. so if you add a new socket its gotta be RCD'd. either by RCD spur, RCD at DB, or RCD socket if cable doesnt need itForgive me if ive missed something, but the new regs are not retrospective, so if you are adding to existing circuits you cant force client to have rcd protection added to the circuit.Maybee just add disclaimer to cert.
say if the new sockets added were wired surfaceif you add to an existing, what you add has to be to new regs. so if you add a new socket its gotta be RCD'd. either by RCD spur, RCD at DB, or RCD socket if cable doesnt need it
if surface, cable wont need RCD, but socket will need RCDsay if the new sockets added were wired surface
