Rcd/rcbo
Ucatchmydrift
Jun 21, 2022
135
31
Suffolk
Hi, im building an off grid system.
I have 2 sheds/workshop that i have mounted the solar panels onto the roofs.
From the inverter inside one of the sheds i have power coming out, going through a 2p 25a mcb (as required by the inverter manual), i also have an isolator switch. From there, swa cable going into the house.
Inside the house i was installing a metal consumer unit with a 32a rcbo and another isolator.
Now, the question i have is, which type of rcbo would be best for my application? Type ac, or type b? As i have read that type b are often used for pv systems.. But im certainly no expert and wondering on you guys opinions?
Thanks again 👍👍👍😁😁😁
