BTW I've never seen an RCD device that can be added on to an MCCB, nor an MCCB with a built in RCD component. Large current RCD's are available, but lostit's post #22 I am in agreement with, in regard to the availability of large rating RCD's.
However, I don't think you can get an MCCB in a low enough value to adequately protect a cable supplying a typical smoke or fire alarm that would fit into the device terminals. That is less than 10A typically!
So how an MCCB could be fitted directly to a fire alarm supply I don't know.
However, another item for thought. What if there is a requirement for "upstream" RCD's.
KME you seem to have the standards to hand...
However, had enough for today, been busy in front of pc and other things, early night methinks.
All the best all speak tomorrow.
:good night:
