gselectrical
- Oct 13, 2009
- 627
- 0
Slate ground. (again) The house is far up in the countryside. Transformer supplying house is 500m away on a pole. There are 2 rods installed. 3 metres apart.would agree with the over 50v touch voltage shutting down your meter,if the RCD is tripping out at 1X then it should be tripping at 5X by logic,
it is a fairly high Ra you have,
you really need to try get it down a bit, couple of hundred ohms hopefully,
how many rods installed, what sort of ground is it?
you can get some crystals to help, or salt water, or the ubiqutious wet around the rod(just dont get seen )
GS
