- Nov 28, 2009
- 14,848
- 1,036
Possibly not on the test button, it depends exactly what that does, but certainly testing with an RCD tester, that creates a L/N imbalance and BOTH RCD's would see that when testing the second one, so both would trip, and you wouldn't know which one your meter is showing the trip time for.I see no reason for the upstream device to trip, either on the test button or when testing with a meter.
See above.There should be no reason for it to trip, but they do!I install a lot of redundant series RCD's and there is no telling which one trips first.
No, what the OP is talking about is two RCD's in series. And as above, both will see the fault current and both will trip. That's precicely what the OP is wanting to achieve, more chance of a trip in the event of a fault.The RCD's are not in series - they are in parallel in electrical terms. Who's a pedantic little ****!
I was just pointing out that doing a proper test, i.e where you want to know the trip time, is difficult. If you are happy just to know that they do trip and don't care how long it takes, then testing is not an issue.
