No. It just happens when the conductors are very close, ie the moment the switch is opened (or closed).Does that basically mean that current could then still flow even in the off position?
When an inductive circuit is switched off the current cannot instantaneously jump to zero; a transient arc will be formed across the separating contacts
No it's a normal occurrence.Ah, I see. Is this then caused by a deterioration of the switch mechanism i.e. contacts?
yes, but only for a split second until the gap is too far for the electric to arc over.Does that basically mean that current could then still flow even in the off position?
Can you just explain the bit about the 10amps light switch and 100amps double pole isolator Sellers, I'm a wee bit confused by thatalso, light switches and other switches are rated to deal with arcing and operating. They are rated to switch a maximum amount of current before the switch will deteriate or operate dangerously. For example a light switch may be rated at 10amps, and a double pole isolator at 100amps.
It's the rating of the particular switch, ie the load it can handle safely for prolonged periods.Can you just explain the bit about the 10amps light switch and 100amps double pole isolator Sellers, I'm a wee bit confused by that
Is silver used on the contact points ?Arcing causes deteriation of the switch contacts.
