Lets say that the main circuit breaker has 40A, RCD 40A, we don't have a comb busbar, and we have to do bridges manually between 5 MCb with 25A, 20A, 16A, 16A and 10A respectively, which is the site that must be used in the inner sections
I provide a diagram to show which are the cables I'm referring to, labelled as: A, B, C, D, E and F
PS: I'm using the 1P+N model because it's common where I live, but you can also imagine that instead of two poles there is only the live wire between MCBs and RCD. I only need to understand the best sizes for wiring.
