Mike Wright
- Mar 20, 2016
- 19
- 0
So, some background.
The house is 1978 ish build, brick and tile.
It's never been rewired.
The old wire fuses are all plug in mcb's except one which I can't identify and is either a direct connection to the immersion circuit that isn't working or the feed to the old bar heater I took out.
The existing shower is switched outside the bathroom and voltage dropped via a transformer.
I intend to replace switch with a wall mounted mcb's thing as new shower takes 240volts into shower unit. This will also hopefully be earthed as 3core cable is used.
Will this be enough? I assume the original earth bonding is still present but how would I know? If I check continuity of the existing feed pipes to the earth running back to consumer unit, and it's less than 0.05 ohms, can I be satisfied bonding is good.?
Mike
Mike
