Well, I've just got a few quotes for what I thought essentially boiled down to some rewiring, and blimey, it's a mixed bag, ranging from £120 to 400. And I'm confused, so if anyone in the know is willing to read the details and give me their thoughts, I'd be grateful.
To give it some context, when we moved into this house we inherited a load of 12v (MR16) recessed halogen spotlights upstairs, which I tend to regard as a triumph of pretty over practical. Each burning a 40 or 50 watt hole in my wallet, but not only that, doing their best to burn a hole in the loft insulation that is laid right over the top of them. Pull the insulation back, and we can see it's blackened and the wires under there don't look that healthy either. The main objective has to be making it all safe, but it would be nice to take the opportunity to 'go LED' at the same time if the economics work out (the preference being GU10 LEDs rather than 12v MR16 + new LED drivers).
No fancy units here, they're little more than a decorative ring (held in by sprung clips) within which sits a lamp, connected to nothing but a wire with a simple MR16 connector on it. There is a metal clip that holds the lamp in place - remove that, and the lamp drops down and just dangles there on the end of the wire (along with some dust, maybe a dead spider and some wisps of insulation). So, plan was to get someone to strip the lot out, put in fresh wiring and drop GU10 connectors into the existing lamp holders. Then I could find myself some decent GU10 LEDs and job done.
To summarise the quotes, they went something like this:
:yawn Mister A: happy to quote based on a description over the phone. Agreed that it should just be a case of replacing wiring and connectors as per the plan above, and I would supply the lamps. Cost: £120 incl parts and labour.
Mister B: came to look, said he'd change wiring (and get rid of the transformers) and put GU10 lamp holders into the existing fittings. Also advised that because one of the lights is a combined shower fan & light, this should remain low-voltage and so estimate includes supplying new LED driver for that, and also includes the LED lamps for all fittings (x12). Sent estimate of £300, P&L.
:B- Mister C: came to look, made same point about the shower light unit (stick with 12v but swap transformer for LED driver). But, Mister C also checked the consumer unit and noted that there's no RCD protection to the upstairs lighting circuit, so apparently due to building regs having moved on, he'd be obliged to address that at the same time and provide a certificate for the work. Sent quotation including labour of £210 without lamps provided, or £290 with.
:wacko: Mister D: came to look, said all the fittings would need replacing because you can't just get standalone GU10 connectors - they come built into a connector block as part of a lighting unit which houses the lamp and includes the decorative surround for the ceiling too. Advised IP65 rated fittings for bath/shower room. Called with quotation of £370 for new fittings and lamps (replaceable), or £400 for different fittings with integrated insulation guards but no lamps included. Includes labour which would apparently involve enlarging the holes in the ceiling.
So, as I say, some quite different outcomes there and it leaves me wondering which on earth to go for, or whether I should just sack off the whole idea, get the plant pots and live with the halogens a bit longer - otherwise it's going to take those LEDs/fittings a good while to pay for themselves.
Some observations:
Thanks...
Some observations:
- Although Mister D had a look at the consumer unit, Mister C was the only one to say it needed MCBs fitting for the upstairs lighting. Is he (a) to be applauded for being correct, and safe, and on the ball with regulations, or (b) misguided (or © trying it on... but I'm guessing not)?
- Mister A didn't even need to come and look. Is that (a) because he quickly assessed it's a simple job and I should rejoice in his cheap quote and get on with it, or (b) a bad sign and I should step away gingerly?
- Mister D advised IP65 fittings for near the shower (definite) and bath (advisable) - suitably or overly cautious?
- Mister B made the point about the shower light remaining low voltage - presumably that's a good idea (maybe the only option... guessing the lamp and fan have separate power but not sure)? That's a very round estimate he sent me there...
- Mister D was the only one to propose insulation guards - the others were fine with my suggestion of using plant pots (not plastic, obviously)
- Mister D reckoned there's no option but to replace all the fittings, but Misters A, B & C seem to suggest otherwise. What's that all about?
- If I do get them done, maybe I should forget the shower one and just leave it as 12v halogen (so no need to fork out for new driver)?
Thanks...
