Hi all
I'm rewiring a kitchen and the only way to get the Ring return leg 2 is through the same chasing it came in as there's no direct route to the other boxes sockets.
Is it ok to pass the return leg through the back boxes or do I have to chisel out more under the back boxes to pass the return leg?
Please, see attached picture. On the left side box is the wire which will come back to each backbox/socket for the wiring to take place in loop in loop out mode.
Thank you
Thank you
