Hi Guys (& Gals) came across a ring done out in 1.5mm cable at the CU. Customer says it was put in 15yrs ago. Customer says no to upgrade due to carpets flooring etc. My problem is do i put it on the EIC as a deviation? There are only 3 x double sockets on the ring & only standard lamps fed from it. Tests show everything is ok. Any answers appreciated.
