Have just been out to a job to look at a fancy SELV halogen light where it stays on for a few mins, then goes off and wont work for 30 mins. Assuming it's the transformer so cut it out and will try to get a replacement tomorrow.
I checked the supply voltage and across switched live and neutral I was getting 238V with the switch on, and 53V with it off.
I haven't looked yet, but my guess is that there is a loose wire in the switch, and the live is touching the switched live, maybe loss of seperation in the switch mechasnism itself or even damaged insulation on the switch drop?
Does this sound right, or can you suggest an alternative cause i'm missing.
The cables in the ceiling looked well terminated and isolated from each other.
