I'm in the process of switching to octopus go. My enquiry is regards setting the inverter to charge between the low rate hours 1230am-430am.
Inverter is solis RHI-5g 3.6kw hybrid
I've looked through the manual and the only page I can see is the one below.
Is it just a case of setting the T charge (graph 1) to 1230am-430am or do I need to set the T discharge time also. 430am-1230am.
Do I need to alter the charge/discharge current from 50.0A
In this image, it shows the reserve SOC pre set at 80%. Do I need to alter this ?
