paulh
- Jun 4, 2008
- 144
- 0
I am currently working on a contract renewing industrial lighting (simple swap out...yeah)and came upon a dodgy situation today.
I was trying to isolate the lighting (lot's of it)and after turning all the mcb's off individually I realised I couldn't turn all the lights off? I then turned them all off and finally darkness!!!!!!!!!!!! The lighting cct feeds are all joined up one way or another thus at least dual feeding the cctsX( which are incidentally on 16amp mcb,s and installed in conduit(imperial)
This installation is at least 30 years old with what looks like no alterations except the odd fitting changed here and there. The original flourescents are all on really old 2 amp 3 pin plugs with soldered connections. I took one of the conduit ceiling roses off and as suspected there is no earth's either. I have been told the building has been inspected?????? obviously by a welder,joiner or plumber certainly not a spark. As you would suspect it was a job stopper. I can't make my mind up if it's wired wrong or there is water/mechanical damage somewhere. my gut feeling is heading towards wiring
It look's like a simple job may make me a millionaire eh.....ho..hum
