i assume you've got to be qualified to pat test(2377) not just a competent person?and use correct equiptment?
well at work there's a bloke doing pat testing and doesn't seem to have a clue, failed a stereo (Class II) for having no earth?, lets a power drill a (IEC 'Kettle type' lead) extension to be used even though it's wired the wrong way so the pin(male) ends connected to the socket leaving exposed live pin? does't check cables/grips for damage or correct fuses, somehow i don't think he's qualified
also his 'PAT' tester is an analog meter (dial with pass or fail) with a socket front,where i used to work we had a tester did the works , continuty,insulation, flash ect,
i've done C&G 6958 (electronic/Electrical service & repair)
and C&G 2330 Level 2
