Short Delay Timer
kme
Fridge Keyholder™
Mar 7, 2008
9,984
In the office again.
So......
We`ve got a few florries fired from one switch position - I`m spreading them over three phases.
the plan is to fire them through contactors; with the second stage a few seconds after the first, and the third stage a few seconds after the second ( avoiding inrush).
Apart from using the Lovato TMM1 timers, which are very good, but seemingly overkill - any other ideas for a few seconds delay on the control circuit?
Ta.
KME
Cascade the contactors, with 1 on/off switch controlling the first, & contactor mounted, on delay timers feeding the subsequent relays.
As Sidewinder says cascade the contactors but maybe by fitting a pneumatic delay auxilliary to all but the last one. If you just use the built-in n.o. aux contact you'll probably only achieve a few miliseconds.
Nah guys - you get me wrong.
I know HOW to do it - piece of p155 - I wondered if anyone knew of decent delay units..............
S`okay - I`ve found a star/delta timer, with delays on each make ( settable) - so I can fire that from the n/o of the first contactor, and it`ll bring in the second, and then the third, after a few seconds.
Thanks anyway,. Sorry I didn`t explain the question very well - probably too much influence from Capt. Morgan, esq. ;)
Why not use contactor mounted timers?
Schneider do them to fit their contactors and they are in stock locally.
Less devices, less hunting for bits.
I don't understand why you want a separate timer?
Oh, and remember panel standards! ;)
