my initial thought but i mentioned i would talk to a friend whos a plumber and he was quite insistant that it wasnt a plumbing problem - sounded to me like he had a plumber round who had blamed the wiring!Sounds like a Plumbing job then, maybe water flow too low when Heating on to trigger flow switch in Pump.
ive used a pneumatic push button in shower - air line to a pneumatic switch, and connected to existing switch in pumpAvailable commercially as a "negative head switch kit" for shower pumps.the flow switches are magnetic in nature - we`ve done a mod on one with an old type doorbell - induce a magnetic field around the flow pipe, and the pump`ll start
KME
Depends on a few things like if its a combi maybe it can't heat enough water fast enough with heating on too so flow isn't high enough to kick pump in but I would guess its a gravity fed system with a pump (otherwise why need a pump) so it could also be some funky wiring somewhere. Guess until you bet a voltmeter on the pump and check its still got power we cant really tell if its lack of power or lack of flow rate.surely the water flow through the shower pump shouldn't be affected just because the heating is on?
Can I just clarify something here - Combi`s are fitted with a "diverter valve", which is the piece of kit which tells it if its heating CH or DHW. IF the heating is on, and you turn the tap on, the boiler stops throwing heat to the rads, the diverter moves across, and your mains pressure water is fed through the heat exchanger. The flow rate of a combi doesn`t drop because the heating is on - it "diverts" the heat away from the CH to supply hot water while its being demanded, then drops back to CH when the hot tap is turned off.Depends on a few things like if its a combi maybe it can't heat enough water fast enough with heating on too so flow isn't high enough to kick pump in.
other than the filling loopIn neither case does the water circulating through the heating system have any connection whatsoever to the water that comes out of the taps.
Yup, its on the "multiple RCD" thread - impervious(do we have a word of the day?)
