So I assume you have followed the NIC official complaints procedure to get the works rectified??Being a member of NIC means F all. While I was away travelling my parents had a new kitchen fitted and the kitchen company employed an NIC approved contractor. They have not provided a cert, not fitted fire hoods on recessed lights ( which has a bedroom above), fitted an additional cu fed from existing board instead of fitting tail blocks and feeding with a new set of tails, the existing cu did not have any spare ways so they doubled up upstairs and downstairs lighting circuits.What's the point in paying NIC if they still allow the cowboys to be Part P certified. It's all a con. They only want your money and then don't give a F what you do.
Just cos you are Part P does not mean to say that you aren't a cowboy!
and what are the contraventions ?Being a member of NIC means F all. While I was away travelling my parents had a new kitchen fitted and the kitchen company employed an NIC approved contractor. They have not provided a cert, not fitted fire hoods on recessed lights ( which has a bedroom above), fitted an additional cu fed from existing board instead of fitting tail blocks and feeding with a new set of tails, the existing cu did not have any spare ways so they doubled up upstairs and downstairs lighting circuits.What's the point in paying NIC if they still allow the cowboys to be Part P certified. It's all a con. They only want your money and then don't give a F what you do.
