Mecanic Mike
- Joined
- May 27, 2019
- Messages
- 2
- Reaction score
- 0
I need to change this unit the lead flex dissapears into the ceiling void and
I am unable to disconnect it from, apparently a connector unit.The fault was the control let the main heating Circuit open when only the hot water should be on.
The motor unit was hot when every thing was turned off!
Would changing the motor unit only be the easiest solution?
