Single Phase motor wiring question
mecheng46
Active member
Jan 26, 2020
42
I recently purchased a very old and heavy duty single phase bench grinder and I am trying to put some life in it. The motor manufacturer label can be seen here:
The motor is a single phase 240V, 1HP, 50Hz, 6.1A, 1500 RPM.
At the moment there is DPDT switch wired on the motor and no capacitor. The capacitor possibly has been removed at somepoint.
https://ibb.co/rKhQmSg
The 15A/250V toggle switch wiring as it stands is:
1 - Mains power blue - Neutral
2 - Motor Cables 2 & 3
3 - Motor Cable 1
4 - Mains power brown - Live
5 - Nothing
6 - Nothing
Although the toggle switch has three positions only two actually do work. The middle which is the Off position and one of the side positions. When I flick the switch to the On position the motor is buzzing and with a bit of push it eventually goes up to speed. This motor should only run in 1 direction but something must be wrong with the wiring because the direction of it when on the On position is 50/50. Sometimes it runs clockwise and sometime anti-clockwise.
It sounds like I need to start from scratch which is 3 wires on the motor (not colour coded) and 3 wires on the mains plug, a toggle switch and possibly a capacitor.
I like the idea of having a DPDT switch with reverse polarity if possible so i can use the grinder in either direction but I am a bit worried that I might flick the switch to the opposite direction by mistake. I am not sure if DPDT ''safety'' switches exist.
To start with I am looking to get the grinder back in working order with 1 direction and without me having to push it to start.
sounds like the start cap is faulty (or missing, as you said it may have been removed) & needs replace or the start winding is open circuit
Thanks for your reply Andy, yes the start cap is definitely missing as I have to push the motor to get it going. Also it is possibly the problem with the wrong motor direction.
I really need to start from scratch with this as the wiring as it stands now it has no capacitor involved in the wiring. All I have for now is 3 wires from the motor, 3 wires on the mains and a switch which it might not be the right one. The motor needs a capacitor somewhere
You don't need to start from scratch. You need to get a capacitor and connect it and all will be well.
Are there any signs of cut off bits of cable on any of the motor terminals to give you a clue where it might have been connected?
The wiring is messed up by the previous owner and it's impossible for me to say what the original wiring supposed to be.
No signs of where the capacitor was originally. Also the switch that is currently on the machine doesn't look to be the original, it's an On-Off-On switch and has 6 terminals which only 4 of the terminals are used. The original switch would be an On-Off with the motor rotating in one direction only.
Another question is what size and what type capacitor do i need for this motor?
the fact there are spare terminals on the switch is irrelevnt. usually the switch would be a 2 position but yours is 3 so you effetively have on/off/off instead of on/off. there are also plenty switch with the same terminals that are just on/off
you need to find where the capacitor goes and fit it. chances are, thats all it needs. there are plenty disgrams on google for single phase motor wiring / windings. you need to find the start winding and fit it to that. if you have 3 cables sticking out of the motor, where are they conencted to? there is usually 4 (2 per winding) but it could have 2 connected inside the motor making only 3 on the outside
Taking the bench grinder motor apart would be my last resort as it not as simple as it sounds. I am hoping that somebody came across this type of motors in the past and might be able to help. Google and all the wiring diagrams are not helpful due to the age of the motor, I can't find a wiring diagram of a single phase motor with 3 wires coming out of it.
Okay, so you have 3 wires coming out of the motor.  TWO are presently connected, to L and N
So the third is the starter winding.  We just need to know if the other end of the starter winding is internally connected to L or N.  Do you have a multi meter to take some ohms readings?
Much appreciated for your reply Dave.
Two of the motor cables are connected together at the moment.
Yes I have a multi-meter, what readings do i need to get?
On a H&Safety issue  ,   you don't need a bench grinder that turns either way  , its an accident waiting to happen .   In my experience they spin down towards the tool rest or bench ,  spinning the other way could throw a piece of work up, unexpectedly   at the operator.
Never mind it unscrewing the nut and the disc coming off!
tool,jams
nut undoes
disc goes all moody
tears all,around
I will get some readings tomorrow from the motor windings :)
As I mentioned on my first post, I am not confident having two directions on my bench grinder without some sort of a safety device. On a side note, Tormek market their grinders turning clockwise.
I also can't think of a good reason to have a bench grinder run backwards. Apart from anything else it would direct the detritus into your face rather than down the guard .
Presumably you are electrically knowledgeable enough to know the importance of checking the insulation of this old machine.
With a machine of that power and age there could be a centrifugal start switch. I would be inclined to be dismantling it to establish just what I'm dealing with.
