single phasing of 3 phase boards
hxsarge
Apr 12, 2011
300
does anyone know the rules about single phasing three phase boards? in the past i have used a henley block to split the supply up into 3, and put a Danger single phase label on the front. i know manufacturers do sell single phasing kits, just wondered if there is anything wrong with doing what i have done in the past?
im currently working on a large 5 bed detached house with several out houses and a large office/garage. at the customers request, and a good idea for the rich, each room has its own radial circuit, be it a 20a 2.5, or a 32a 4mm. also each room has its own lighting cct. and yes thats a hell of a lot of rcbos when you take into account the 2 ovens and 2 showers, plus out houses. Im using a kq db.
cheers andy
I can't see anything wrong. Do you even need to label anything? Having all 3 phases of the board on the same phase makes it less hazardous than when wired as a 3 phase board, so I can't see an issue at all.
yea thats what i thought, although i noticed i went back to that 1st job the other month to find a local authority sub contractor had wired a new spur for a stair lift and noted on the cert that the voltage was 400v and it was a 4wire 3phase supply. lol.
See my views on that in this thread http://www.talk.electricianforum.co.uk/electrician-talk-forum/19321-gs30-approved-voltage-tester.html
He probably doesn't even own a volt meter or have the skill to use it.
But then it should have been bloody obvious. The single phase head and meter should have given him a clue.
I think I should quit reading the forum. I just keep reading about stupidity like this, and at the same time stupid rules for those that actually know something. : headbang
yes especially when you consider the local subby was a well known large niceic firm and not just your average dope.
As long as each single phase board is set up so that no two phases can be installed in the same vincinity I see no problem with what you have done. Distribution of power is normally acheived this way either single or 3 phase. I prefer to use 3 phase when its installed as it gives me more flexability in design.
I think you missed the point.
He's used a 3 phase board on a single phase install, with the single phase available feeding all 3 phases of the board.
This is a convenient way to get a MUCH larger single phase board than otherwise normally available, due to the customers requirement for a lot of circuits.
I think you missed the point.He's used a 3 phase board on a single phase install, with the single phase available feeding all 3 phases of the board.
I use the same method from time to time. However the OP stated that he used an Henley to split into three, from this I thought it was a 3 phase supply but distributed individually through distribution boards as single phases. I could be wrong though,I often am.
