learningcurve
Hello, thanks for being here as I've picked up lots of tips along the way
I have recently boarded my loft and wish to utilise it for storage (i live in a flat)
I am currently plugging in an extension lead every time i go up and down which is not good
I have a small utility room with a single light fitting on the ceiling, with a single switch inside the door
I opened up the ceiling rose and discovered its the first in the loop and therefore numerous wires
I want to be able to install a double switch in order that i can run a light in the loft
from what i have gained so far i will need to run a wire from the existing ceiling rose, QUESTION: Which one?
then what do i need to do with regards to the switch?
Please answer in step by step if possible please and thank you in advance
