dazcardiff
- Aug 30, 2010
- 2
- 0
I've got sky downstairs and want sky to work upstairs in bedroom.
could anyone explain please?
Thanks in advance
Thanks in advance
The SLX is old hat now, they are big and ugly. Use a mini magic eye, something like this.Both posters are correct. You want one of these:http://www.tlc-direct.co.uk/Main_Index/Aerials_Index/Sky_Remotes/index.html
The bottom item - SLXlink - goes in line by the upstairs TV, and pick whichever remote you need (standard or sky+).
IIRC, the instructions with the SLX tell you how to switch on the 9V "phantom" supply to operate the unit. Simple & straightforward.
HTH
KME
TBH, I don`t see a difference between `em - the link you provided looks the same as the TLC SLX.The SLX is old hat now, they are big and ugly. Use a mini magic eye, something like this.http://cgi.ebay.co.uk/NEW-Triax-Compact-Sky-Magic-Eye-Link-Small-UK-Seller-/190307522114?pt=UK_ConEle_SatCableFreeview_RL
Other than the IR reciever, can`t see mine, its behind the LCD.Hardly see them once installed.
Thanks for the info - can you tell me what the difference is between the "old hat" SLX, and the mini eye you linked to?Also if you want sky on more than 1 TV upstairs use something like this http://cgi.ebay.co.uk/SLX-6-WAY-Distribution-Amp-Booster-Freeview-DAB-FM-/310238220738?pt=UK_ConElec_TVAerials_RL
By going from 2nd output on sky into the distribution amp and then routing from the amp to each TV
I've used this exact same one and now have sky available in 6 different rooms (you can only watch the same sky channel though) and all TV's also pick up all the freeview channels by using this setup.
Don't think so as the receiver can only produce one channel at a time not sure about sky plus though.hiexcuse my lack of knowledge in this field but does this mean you can watch different channels to whats on in the other room
gonna find that coax out the shed if so, and invest in the magic eye thingy ma bob.
no. all rooms will be the same channel as the sky box.hiexcuse my lack of knowledge in this field but does this mean you can watch different channels to whats on in the other room
That is true, but remember that it will take an aerial feed from the same coax so can have a freeview box if not built into the TV.Don't think so as the receiver can only produce one channel at a time not sure about sky plus though.
presumeably designed like that to make you pay for the extra box...But, even with sky+. you can`t output the two different channels on the RF lines (unfortunately). So you have to have the same channel showing on both - it seems the second tuner will ONLY record to the internal drive.KME
The "old hat" SLX has a big ugly IR receiver, the link I posted has a receiver which is tiny something like 10mm x 5mm base and about 4mm tall, you simply don't notice it once its installed. Everything else is the same, though some makes use the F-connector rather than a normal coax connector.Thanks for the info - can you tell me what the difference is between the "old hat" SLX, and the mini eye you linked to? Thanks
KME
