/\ Now, all of that is a fact of life. I could not have said it better .
If the back box was not earthed what caused the short, ehh ;Rough. Bet the back box wasnt earthed.
Hi i have just bought a newbuild house in the north east of england. I have had an electrical problem with my downstairs sockets keep tripping the trip switch and rcd switch. I have traced this down to a live wire been sliced into by the electrician leaving the metal cage behind the socket fascia screws loose causing a small fire behind the socket when it has cut through the live wire. I am after some info on weather its acceptable for two earth wires in a socket to be ran through 1 sheathing drilled through one hole behind the socket. Does this break iee rules? Need some info before i play holy hell with persimmon homes. Regards Anthony
erm...........He didn't say ocpd or rcd tripped. If line conductor wad knicked could just be arcing on back box causing the burning.
Mmm feel bit silly now. Im off to specsaverserm...........
Read start of the first post...
trip switch and RCD keeps tripping.. ???
:coat
May not have a fly lead...Rough. Bet the back box wasnt earthed.
1/ plaster board is pretty heard to set fire toYes it all good saying that the circuit breaker did its job but nobody can tell me with 100% confidence that it could have ended up worse if the insulation etc behind the plasterboard caught fire.
