- Mar 28, 2008
- 14,487
- 1,155
Hello peoples I been to busy recently to get on ye ode forumulations..
so just a quick visit to say hello again
indeed GH....First question the answer is no, they should be fitted lower and depending on the length situated on opposite sides. 300 mm is the recommended distance from the apex of the roof.question 2 the minimum stated in all litrature is 300mm.
question 3 if wired to the lighting circuit you wire live neutral and earth. The dimmer works on the switch cable only and would not effect smoke alarms.
the veterinary thinks it's more likely to be dute to warmer air temperatures and the warm air arround a light displacing the smoke?could they be affected by electrical fields? I dont have anything to do with smokes I'm afraid just guessing here.
You are correct, whilst the minimum distances are a guidline you must always follow the makers instructions.Failure to do that could render you responsible under the professional indemnity insurance.(should the worst happen.indeed GH.... But..
134.1.1 Equipment installed in accordance with manufactures instructions???
I am assuming the "Dicon" instruction sheet has something to do with the interlinked trigger wire susceptible to interference????
but thats just a guess? :|
no...the veterinary thinks it's more likely to be dute to warmer air temperatures and the warm air arround a light displacing the smoke?
it's looking like a dedicated circuit.................... :|no...it says..
Do not install alarms on circuits containing fluorescent fittings or dimmer switches
not close to! Connected to circuit!
No smokes supplied from circuits with florries OR dimmers! :| ? :| ?:| ? :|
tis wot I am thinking patch.....it's looking like a dedicated circuit.................... :|
some here http://www.tlc-direct.co.uk/Technical/DataSheets/Kidde/Index.htmtis wot I am thinking patch..... I need to check some other makes of smoke detector..
see what their instructions say? :|
ffs Patch!
? ; \ ?:|Do not site near fluorescent lights; electronic noise may cause nuisance alarms.
calm down boy!!! :^O:^O
Hello peoples I been to busy recently to get on ye ode forumulations..so just a quick visit to say hello again
