paul b b
hello chaps,
on a re-wire, its a flat and has an entrance on the street with a stairwell at ground level, the stairs have a half landing between floors and the top floor also has a door at the top of the stairs into the hall way.
question is, do i need 2 detectors either side of the door?
i am also fitting a heat detector in the kitchen, is 600mm from door/wall ok or should it be in the center? do the link as smokes do?
thanks one again
paul
thanks one again
paul
