Smoking ban in buildings
Evans Electric
TEF LINUX ADMIN™
Sep 15, 2008
23,507
527
Birmingham
Seeing people having a smoke outside their workplace reminded me of the pre-ban days .       We used to do lighting maintenance  at a large city centre open plan office .  Fittings were recessed  5ft  X  4 lamp  with flat sheet diffusers  .
It was change all tubes , all starters , replace  ballasts as necessary and wash  the  flat sheets which were covered in  thick brown  nicotine .  It was also on the tubes  , dripping onto the inside of the flat sheets.
Although it was  late 1950's  design it was quite forward looking .     The recessed lights   ( 5ft  X  2ft  X 4 lamp)   had an open egg crate  grille at one end   ,  the vent system drew the heat developed by the lighting  up into the ceiling void and recirculated it .
The lighting circuit  was a ring main in the dado power trunking ....  each architect  had  two or three  fittings over his section   ( open plan office)   switched from a spur unit on the dado .
They would often be out on site so their lights would be off .    There was just one row of lights  down the length of the office  which were on all day .
Most large offices  had , say a 12 gang  switch at the door  which the first one in  each day wacked them all on   even in  summer when they made little difference .
