extension15
Distinguished Member
- Feb 13, 2008
- 1,658
- 0
EXT 15Do you always put them at that height (one of my current jobs) Only joking.
Batty
the problem with just turning the plates is if the occupier wishes to put a transformer plug in will have a problem. I would push to move socketNot wishing to be silly but if the socket faces were put on upside down would this alleviate any strain on flexes etc? Now do you have a specific regulation that states yey or neigh?
OK, as long as your paying...the problem with just turning the plates is if the occupier wishes to put a transformer plug in will have a problem. I would push to move socket
is a key point on this one.. also553.1.6a socket outlet on a wall or similar structure shall be mounted at a height above the floor or any working surface to minimise the risk of mechanical damage to the socket outlet or to an associated plug and its flexible cord which might be cause during insertion, use or withdrawal of the plug.
only thing you would get in there is a shaver plug:^O
134.1.1 pg 19 the big read book!The same has happened with CU's too, hasn't it Steps. I haven't come across a reg against it.
unswitched?as has been said...is a key point on this one.. also
NICEIC guidance suggest 100mm as the suitable minimum height.
http://www.niceic.org.uk/myniceic/privileged/nroot/niceic/myniceic/privileged/17thpg7.pdf
I would also suggest you are failing to comply with
134.1.1 "good workmanship / proper materials / manufactures instructions" etc..
An upside down socket would obscure the view of any Red marks or "ON" legend printed on the switch to identify an outlet that is switched ON!!
you should also take account of "External influences" 512.2..
Socket mounted on skirting board greater risk of knocks & bumps from feet / vacuum cleaners, carpet fitters, skirting board replacement.. etc..
Obviously you don't HAVE to go to the preferred 450mm height..
but don't think you can leave them on the floor.
Personally I don't know how you can sign a certificate for your changes saying it complies with current regs???
Like for like.. repair or replace front covers or damaged cables..unswitched?there are no changes, like for like doesnt even require a cert, tho its always good practice to issue one.
but I do totally agree with the good workmanship etc.
but what do you do if no one will pay?
you just gotta note it on the cert, but it is only a 'requires improvement' at most.
Evening all, I have been asked to rewire some sockets but the client wants the as is, they are at the moment on the skirting ( 7 inch ) and surface mounted the carpet will just slide under the surface box, is this acceptable ??????, the client wants minimum damage.regards Iain
I guess I need to pay more attention! BlushingLike for like.. repair or replace front covers or damaged cables..but I read the initial post as rewire part of circuit? ?:|
not really like for like in my book? :|
currently working on a new build to the 16th edition and the client wants sockets at 300mm and switches at 1350mm. Now i know that 450 and 1200 are quoted, but in the on-site-guide it also says that in Scotland (we are always different).What's the problem with them?The 450 & 1200 refer, in particular to New builds. And some New extensions (Dependant on how your LABC is).
There is no requirement for example - on a rewire - to place them between 450 & 1200mm. It depends on the specs of the job. (IE: if you were rewiring council properties, then chances are they would spec them at between 450 and 1200 mm).
But I do agree that the 7" skirt mounted boxes need to be adjusted, too avoid stress on the flex etc.![]()
you are fine,currently working on a new build to the 16th edition and the client wants sockets at 300mm and switches at 1350mm. Now i know that 450 and 1200 are quoted, but in the on-site-guide it also says that in Scotland (we are always different).Quote - the Building Regulations are not applicable in Scotland where the Building Standards (Scotland) Regulations apply. The Scottish regulations do not have specific minimum heights for accessories, installations are required to generally comply with BS 7671.
So 300mm for sockets would be ok???? But does the maximum height of 1200mm still apply, anyone know anything that can help?
Not likely, mate. As you say, building reg deals with heights, not the bigred!you are fine,to generally comply with 7671 would be in a safety aspect, nothing to do with heights or otherwise, that is a building reg.
put them any height you want.
bet some1 corrects me now.
