Page 11 Part M
"Where the requirements apply
Application of Part M
0.1 The requirements apply if:
a. a non-domestic building or a dwelling is newly erected ;
b. an existing non-domestic building is extended or undergoes a material alteration; or
c. an existing building or part of an existing building undergoes a material change of use to a hotel or boarding house, institution, public building or shop (explained in Regulation 2)
Section b. above is the pertinent section as, under the regulations, material changes in dwellings are affected in as much as
You are not allowed to make changes that would worsen any existing compliance with part M, or that changes or additions themselves are less compliant with that existing. (if a building has been designed with Part M in mind, any changes etc, must comply) say if you were rewiring a house built after Part M was introduced)
This would apply even if the existing 'compliances' were by default in design or planning (usually predating Part M), or had been planned with Part M in mind (Post Part M)
if a dwelling already complies - you cannot do anything to make it worse! by way of exanmple: if he sanitation is Part M compliant and the sockets are not, you can put sockets in where you want, but cannot alter the the sanitation so it is less compliant
I hope this helps with the understanding.
