I have done that a few times on switches with a lot of cables but if I do I twist them round that way they can plaster around fairly easily. If you leave a big lump of cables they will just cut them off *******s.Leave about 12 inches of cable sticking out. That normally stops them filling them in. They can't stuff it all in the box. (leave a note up, DO NOT CUT)
Or a sign saying Warning Live cables!Leave about 12 inches of cable sticking out. That normally stops them filling them in. They can't stuff it all in the box. (leave a note up, DO NOT CUT)
Plasterers aren;t well known for being all that clever.every single switch and socket has been plastered in flush because he said the screws wernt long enough!!??? are these people for real?
of course he knew, but surely common sense would suggest you dont go and do that. then the fact he had done it throughout was a joke. yeah we had to 2nd fix before it was patched up unfortunatly. not something im too fond of as i like to do things in order but 1 thing you dont expect is your fellow tradesmen creating you even more problems. worse thing was the customer couldnt see what my problem was!?? dont know why i bother sometimes..He must have known you can get longer ones ? surely ?..... how come the fronts were on anyway ?. I'm guessing you had to 2nd fix before he came instead of after.
Cooker outlets are a favourite one for thatheadbangoh and yeah looks like weve had a nob ed tiler too who has tiled up to the kitchen sockets so these are now flush with the tiles and the outlets and switches are now solid with grout! headbang
use a thread off of some gaffer/bodge tape & put it on the van door paintwork looks just like a key scratch.......gets a reaction every time]I like annoying tilers by drawing cracks on the tiles with pencil. gets them every time!
but the plasterer would just plaster over them too!Can't remember where IO sawa them now but did see some boxes that can be put over the back boxes to prevent the plasterer from plastering over them, you then remove them and second fix! Thought ohh thats a good idea when I saw them as have had boxes disapeer a few times but forgot where I saw them now
the sparky :_|Use the yoozy boxes next time they are only pennies also had this problem myself customer went ape i suggested flat plate accessories most are bigger than standard type and will cover and sit perfectly oh and guess who had the cost knocked off their bill.
