Hi. After solar panels were installed, pigeons moved in, and I then had wire mesh installed. I started getting DC isolation faults from the inverter monitoring platform whenever it rained following the recent heatwave. Once the roof dried out, the panels seemed to perform as normal.
The installer has investigated and lifted the panels. The isolating plate at the bottom of the panel has been damaged by the metal spikes of the mesh - there are holes and gashes. I have 12 LG panels, 9 of which are damaged, but I have recently seen that LG have stopped making panels.
It has been suggested that these panels cannot be repaired. If the panels do work OK when it's dry, would it would be possible to fill any pierced areas to protect against moisture. I am not sure at this stage whether any cells were affected.
I would be interested to know if anyone has had experience of this kind of damage.
