- Aug 3, 2009
- 1,792
- 262
Are they not going to need to mine a lot of platinum to make those hydrogen fuel cells.
Good point Roys. The industrial use is their main driver. Looks like Japanese electricity is to be nuclear with hydrogen as a side product, so I can only see EVs used, using hydrogen in the likes of trains, trucks and ferries for vehicles. When they made the decision to go hydrogen, battery chemistry was not like it is now. We will see how it pans out.Are they not going to need to mine a lot of platinum to make those hydrogen fuel cells.
nothing cheap about nuclear anything, plus you have to add the costs of the waste, but interesting. Another idea I've seen is to locate fertilizer plants next to steel works. Apparently that releases hydrogen as part of the chemical process.Look at the Utube link I gave about how hydrogen is made. It is actually happening right now. And cheaply.
They are near getting two for the price of one, electricity and hydrogen. That is why they chose the HTGR reactors. They operate at a much higher cooling temp, using helium as the coolant. The very high cooling temp is ideal to produce hydrogen.nothing cheap about nuclear anything, plus you have to add the costs of the waste, but interesting. Another idea I've seen is to locate fertilizer plants next to steel works. Apparently that releases hydrogen as part of the chemical process.
Australia was looking at large-scale reactors and small modular reactors (SMR). That is very different to the Japanese approach of HTGR reactors cooled by helium making them idea to produce hydrogen, to replace fossils fuels used in heavy industry.Have a read of the article below. Japan is quite different to the rest of the world due to the nature if it's land mass, ie it's nearly all mountains. So they will have different criteria to work to, and maybe that's why they like nuclear and hydrogen.
https://www.theguardian.com/news/ng...australia-liberal-coalition-peter-dutton-cost
you will like the Mitsubishi newsletter https://spectra.mhi.com/boosting-gr...ZzKEIK426IPdqkxlY2jf3nH4MUxbDAIUiIlo1WUOz7GAwJapan is the only country with a serious project to eliminate industrial fossil fuel burning.
