You are feeding us the puzzle in pieces.It's a mains pressure water system.
I have no problems with the hot water and upstairs radiators.
They are all working correctly and wired to their own wiring centre.
The ufh controls and manifold are situated remotely from the boiler and hot water tank.
All I need is a switched live from ufh to the boiler.
The ufh diagram shows a live in and live out which I don't understand.
I could take a switched live from the orange wire of the ufh zone valve but would rather stick to the MI's if possible.
It could be done that way, but the ufh controller is remote from the existing wiring centre apparently, so would require new cable runs for all the controls for hw and rads upstairs. I would leave the existing as is, just in case the controller fuse blew there would still be heating upstairs and hw.Having had a quick look over the manual it would appear that the hot water should be wired into this panel and the heating (rads) is wired through the heating in out termination.
I seem to remember the UFH system I wired had a similar panel whereby all heating and water operations were wired through the one panel.
Each ufh zone is controlled by its own programmable roomstat. The hot water and rads are controlled by a separate 2 channel programmer.You are feeding us the puzzle in pieces.
So there's a hot water tank and a radiator circuit that both have a motorised valve and that bit is wired and working.
So with a bit of luck your plumber will have fitted another motorised valve for the UFH.
So the Live in is well live in, what bit of that don't you understand?
the switched L is an output from the manifold and it goes to the brown of the motorised valve for the UFH circuit, so when any one of the rooms with UFH calls for heat, the UFH controller will open it's motorised valve.
Then you connect the orange and grey feedback contact wires from the UFH motorised valve in parallel with those of the other motorised valves. These are already connected to fire the boiler and work.
Just to put the cat amongst the pigeons I hope you have a different time clock for the UFH and radiators otherwise the customer is going to be less than pleased with the way it works.
That's good. A lot of people just put the UFH and radiators on the same programmer and the results are disappointing due to the very different warm up times.Each ufh zone is controlled by its own programmable roomstat. The hot water and rads are controlled by a separate 2 channel programmer.
