Hi Sitting in New Zealand and trying to sort out what seems to be an ancient model of nightstore heater. It is a GEC Nightstor - without any further technical data lable.
It is connected to a room thermostat, which switches it off and on. But if the set room temperature can not be reached the heater seems to keep going and ends up (several times) melting the 144 degree temperatur fuse.
1. What are potential causes for it? And how is it supposed to be avoided?
2. Is there supposed to be an internal thermostat, which could be faulty? (couldn't find one though)
Getting cold and would love to hear some advice.
Chelsea
Well this is interesting, I service storage heaters for 98% East Sussex County Council properties, yes boring job but pays my wage for the company I'm with.
Answer to Chelsea, This does depend on how your storage heater works, is it Element only? Fan assisted? or Convector & Elements majority of the time your room stat controls the fan/Boost thus switching off when temperture reached, can assume room taking time to heat up and click stat off, potential cause could be faulty room stat being temperamental or room stat being to far not picking up good amount or heat from unit, another suggestion could be input stat to storage heater inself not clicking out at required cut off point but if this is the case your room stat should back that up shutting off heater but that could possibly only be controlling the fan not the heat itself, you need to distinguish what is contollering the Heat input first.
TRY THIS it might help finding out
As many say it, is sometimes cost effective to replace over repair depending on the over all condition of the heater shell, components etc, I tend to repair unless I absolutely have to replace commercially.
I use
Capri Electrical Developments Ltd. for reference to many Storage Heaters, wap friendly for those using mobiles on site, have ordered many spare parts for heaters 15+ years old, I don't normally advertise companies on forums however they are highly useful, have downloadable/printable reference page to thermal links on replacements and breakdowns on most models, worth a look.
If I can help in anyway I will try my very best, please feel free to send me a PM
