was thinking with a locking extension bar they would be better in the kit than a standard length oneNot if you have a thick piece of wood?
Wood beavers are ok, just found they didn’t last as long as a Bosch fast cut.
yeh but you cant get the access with the standard length ones sometimesWhy use two piece when one will do it?
Angle drill?yeh but you cant get the access with the standard length ones sometimes
so an angle drill or a hex bit extension, which is cheaper i dont like spendingAngle drill?
Are you new to this? Self employed I presume?so an angle drill or a hex bit extension, which is cheaper i dont like spending
Angle drill, end ofso an angle drill or a hex bit extension, which is cheaper i dont like spending
