Haha. How do you know I'm not already paying double what you charge..
I wouldn’t be queueing up to work for you …..
As a property developer imo i guess it depends on where the cables are.
I wouldn't allow my sparky to run horizontal cables in any other rooms than the kitchen or utility. And even in these areas where possible return below a base unit and back up to the socket.
I appreciate you are the expert but if your client asked for 1 socket in every room when you recommend 3 or 4 would you say they are questioning you expertise?In most other rooms sockets are generally much nearer the floor...
So in many situations dropping vertically down, run along below floor, then back up again is a perfectly logical and sensible approach...
However.. if it is a concrete floor.. Running vertically up a wall, across above the ceiling void then back down the wall to another socket on the same wall is daft, expensive, and more likely to be at risk of someone banging a nail through the cable...
Whereas horizontally between sockets in this situation is the best solution for safety, practicality, cost effectiveness etc..
Horizontal runs are common place in surface runs e.g. sheds, workshops, garages, or in dado-trunking installations..
So why should they not be allowed between any two accessories where the cable is below the plaster?
especially as BS7671 does not prohibit them...?
So to say they should not be allowed is a very narrow minded opinion...
Possibly equivalent to "The tail of misunderstanding wagging the dog of ignorance"
If anyone questioned or doubted my expertise, knowledge, experience etc, in selecting the best installation methods for a particular job, then I doubt the working relationship would last very long?
Why would anyone add unnecessary extra cable length to any circuit when reducing volt-drop and earth loop impedance are design considerations that are best kept the minimum they can be??
I find it strange how an expert would run cables down a wall. Across a wall and up a wall in the same room. Surely for following trades and home owners (and neatness of work) it would look better to run the cables vertical so the majority of folk know where they run.
You give sparkys a good name. Keep up the good workI will continue to do what I think is best AND within the scope of the guidance - not that DIY'ers give a fleck about any of this
There is clear guidance on the webb showing vertical, horizontal, close to corners and ceilings. End of.
trades should know about safe zones for cable runs, home owners, well....Across a wall and up a wall in the same room. Surely for following trades and home owners (and neatness of work) it would look better to run the cables vertical so the majority of folk know where they run.
