gselectrical
- Oct 13, 2009
- 627
- 0
Afternoon all. Just in the middle of pricing a job and debating what cable to use for the sub main. Basically the DB is located 25m from the meter. The cable would most likely be clipped direct.
I intend to install a wylex switchfuse at the meter (with the appropriate rated fuse) to protect the cable.
There are no electric showers at the property (all on boiler) One cooker, 37 Double sockets, 5 fCU's, 34 lights, boiler supply and smokes.
I am debating whether to use 25mm 3-core SWA, 25mm 2-core SWA with 16mm earth, or 25mm Split con.
There are no local wholesalers around here, therefore I order most of my gear online (TLC etc) I can't seem to find many prices online to compare.
Your help is appreciated. J
