musicspark
- Mar 22, 2009
- 368
- 0
can someone tell me how this works?
A 16mm T&E submain from a house to an outbuilding is on it's own switch with 50a breaker, mounted next to the CU in the house and has it's own meter in the outbuilding.
The installation is TNS. and the tails from the incoming Disappear behind the plywood mounting board, come out on the other side of the door at the meter, and finally back behind the plaster and into the CU.
Here's the rub, the supply end of the T&E submain also disappears behind the plaster and is connected independently of the CU. Whether this is before the meter or after is impossible to tell without tearing up carpets, floorboards, lathe etc
this leads me to three questions
1. What kind of joint would be permissible (hidden like that) ?
2.Would it be safe to assume that the joint is between main fuse meter - bearing in mind that the submain has it's own meter in the outbuilding?
3.What would have been procedure regarding this arrangement with the DNO ( both for connection and future meter reading)?
