gt67
- Jun 1, 2008
- 41
- 0
I am after a bit of help/advice with regards to the correct size swa cable to feed a home office approx 40m at the end of a garden.
Requirement to feed:
1 x pc
1 x printer
1 x ADSL modem
1 x monitor
1 x lighting cct
1 x electric heater (oil filled approx 2.5kW)
1 x radio
At the moment there is an swa cable feeding 2 garden sheds which caters for 2 x light ccts (1 in each), 4 x sockets. This is fed from the main house fuse board via 2 more fuse boards (assume they are RCD's) but not checked yet as access not yet sorted. I wasd planning to remove this existing cable so it can be fed from existing boards.
So:
Q1 - in your collective opinions and not seeing the site, does this sound acceptable?
Q2 - would 6mm 3 core swa be suitable if it is clipped directly to a wall or is 4mm OK?
Thanks for any help and advice given,
Graham
1 x pc
1 x printer
1 x ADSL modem
1 x monitor
1 x lighting cct
1 x radio
So:
Graham
