green-hornet
Distinguished Member
- Feb 25, 2009
- 3,741
- 0
will work fine. if you want DP or ability to turn both off, then a switch as M107 has linked to would be betterI have to wire two appliances that can only be used 1 at a time, to do this I have decided to use a simple 2 way switch.Do you think this will work?
could also be done by contactors for switching on-load (just incase)We did a 60A , T/Phase version of what you propose, to power two large air compressors, one is on standby. They had a quote from someone else who priced for installing a second 25mm X 4 SWA from miles away . We undercut them by using a large steel enclosure with a 100A, TP rotary switch ,to be used off load but with the original supply cable.
