The braid is split into two pigtails feed into a slots one each side then the pigtails are clamped between two brass washer tightened down by a locknut .
The GXD type, yes I use them all the time, carry them as van stock, they are a pain in the ar*e, however, when done correctly they offer good mechanical strength which is an advantage in the areas I normally work in!
