Tall post!
MalcyB
Oct 3, 2008
317
Hi All.
Can someone suggest what would be best used to mount two floodlights (on the top), and a waterproof double socket (down below), obviously outdoors.? I did consider fence a fence post but I don't think it would be tall enough?
It needs to be tall enough so the floods are out of reach.
I am struggling to find something that would be suitable.
Any ideas would be good
Malc
You'll probably find both scaffold & unistrut will wobble quite a lot!
What is the application in a little more detail?
Can you not use a lighting column?
It is to be sited close to some dog kennels. The post will have the two floods on the top, to come on when they go to feed the dogs at night. There needs to be a socket at the bottom to run a jet washer. A stand pipe will also have to be installed. I just want to get it to look right and meant to last and not look like a bodge.
