And the second clue is "intermittent dial tone"!not activated at exchangeshe needs to phone BT they will test line from their end
if it is ok and not their fault come back to us
'just moved in' is the clue
In the olden days phone lines were physically pegged out on the jumper frame at the exchange to disconnected the actual copper conductors between exchange and home...can you tell if its activated by testing for the 48volts on the incoming cable or will there be voltage there whether its activated or not?
