testing floodlights
r.b
Feb 8, 2011
379
I know when insulation testing on domestic lights you take the lamps out before doing a test on the circuit.The floodlights I know you have to take the son e lamps out but can I do a insulation test on these fittings ?It wont damage them will it?
Or u could test it by connecting L & N together and testing between earth..
IR test method 2
I'd do L+N to E and note it on cert :)
This test l+n to earth with floodlights, flourescents etc, do I still have to take all the lamps out when doing the test or can I leave them in while doing it?Ryan
Your statement is incorrect and should not be considered as a realistic option for doing PIR's in the real world working to practical timescales for paying customers.
Try disconnecting every transformer, lamp, LV equiptment...
In a ideal word yes every lamp would be taken out and I do, do that if it's possible if it's not then IR test 2 is used
Do u carry out a lot of testing ??
On a new installation, I would test the circuit before terminating into the PIR sensor. On an existing, well, everyone has given you the answer.
