Thermostat
Apr 13, 2008
70
Bit confused on this one as I was going to fit a heating thermostat but after checking on internet last night some website advised not to fit T.stat near rad fitted with trv. However all of the rads have TRV's fitted apart from bathroom. Gas central heating on Y plan, living room with open plan staircase and one rad in living room, and 2 others 1 at bottom of stairs with the other on the landing. Do you think thermostat will be waste of time and would it be best to keep TRV on maximum setting for correct operation of T.stat?
Feb 27, 2008
11,034
I always think it is a good idea to fit roomstat as it makes for easy testing system if you have faults also you can leave it on full and trv will regulate heat also saves fiddling with programmer in summer.
Batty
Apr 13, 2008
70
Cheers Batty,
wasnt thinking so much as ease of use but more about economy and saving money on fuel bills.
Mar 7, 2008
9,994
In the office again.
Then fit the thermostat in a neutral area, away from the direct heat of a rad. Set it to the temp. you want, and adjust the trv`s so that each room is at, or near to, the desired temp. There is no sense whatsoever in installing a stat above or beside a rad. :(
septiclecky
Distinguished Member
Oct 17, 2008
1,844
6
Wirral
When I fitted TRV's to rads in my house I left the one of in the hall as roomstat was located in the hall, this worked well as the hall rad was the last one on the circuit so when the stat called for heat it was the last one to heat up as well as being the coldest part of house downstairs.
