Its you Mate ( Usually is ) (Imagine a winking Smiley face here ...which I can't do until Sidey sends me the secret codes ...I only have Brian ATM) :Cis it just me ( probably is). Or do the majority of Vapers look a bit furtive when having a suck?
On my PC , Binky, if I open the Smiley tag , it freezes the PC for two minutes as the emoji,s slowly load up , then takes forever to scroll down to the originals.you should find the original emojis under the new lettuced ones - as you use them the favourite end up on top of the lettuced emojis.
Noah indeed !!!! No a much later model , the one Moses did the calcs on for parting the Red Sea , powered by methane gas . I'm happy as long as I can conjure up Brians :C :C
;[] ;() ;( ) ( [;] ;[ ] ; ) ; ( ( ) ; ( ) ) Doesn't work for me Sharpie :C ;c :c :C ;C Neither does Brian anymoredeke, semi colon with close bracket
It is actually ...nothing wrong with the PC , they got mixed up between cubits & cubic mtrs : C ;C ;c Imagine a Brian here.Isn't that the same model they used for calculating the cement mix for the foundations on the Tower Of Pisa?
