This made my eyebrows go up!
thank-you for reply, its a interesting topic.
i went to a job the other week where a customers house main fuse had blown ( 60amp ) there was a none RCD board in at the time but the MCB did not trip.
he said the hob rings went bright red then everything just went bang. is this due to the cable over exceeding its rating causing the main fuse to blow ?
Fuses and MCBs have different characteristics, the fuse could be more likely to blow first at higher fault currents irrespective of the rating of the MCB, google discrimination between fuses and MCBs.
Reading your example again;
say two people are showering at the same time in a 10.8kw shower 10800 x 2 = 21600 divided by 240 = 90 amp
plus say mother or the father is also cooking the tea or doing some DIY jobs in the workshop 10.8 plus 4.6kw = 15400 divided by 240 = 64 amp
bringing a total of 154 amp ?
We divide by 230V nowadays, not 240.
