Hi All
I have a job been asked to do. Basically wants garden lights remote controlled. He's bought Wise box for this. At moment he has lights on right which he has been plugging into extension cable fed from socket imagine this have to have in built transformer on plug for these to bring them down to 12v. He also has bought some lights to go on left which are 12v with plug transformer. For these both to be controlled off same circuit and so Wise controlled and for neatest option my thoughts are to cut both plugs off both set of lights take their cables into an ip65 box which can mount to fence on both sides. Then within these boxes have a transformer this one seems to fit the purpose https://www.screwfix.com/p/halolite-low-voltage-electronic-transformer-20-60va/48058#product_additional_details_container ? Then take 1.5mm swa from these round back of out house have another ip65 joint box can join both these cables in then make jump from here in neatest possible way probably at high level into back of out house. Take this cable to wise box which will be mounted on front of out house so will have to punch through for this for cables. Then for my supply nick a permanent live from either light or switch wherever it is. Also changing mcb for rcbo. Bit of a balls ache and bit of chasing to day wit
In out house but for neatnest sack so cables not running everywhere seems about the best I can do.
