We are installing some metal partitioning in work. It's powder coated frames with glass inserts around 7ft high. It's mounted on an existing parquet flooring and bolted through to the concrete slab underneath. Now, I'm pretty sure, when I test it that it will be isolated from the MET so it won't require bonding. However, as there will 6 entry doors along its perimeter, we are required to run some power to each point. The only feasible way is mounting trunking along the top of the partitioning (there is a 100mm rail atop of the partitioning that will take some trunking). My initial thought and discussion with the person installing in was to run it PVC trunking and attach it using nylon bolts. It's only taking 2.5mm singles and not a huge amount of them. Plus, with the PVC we can create compartments should data be required as well. Using white plastic conduit drops from the trunking to the points required. The thinking being all of the electrical items are isolated from any of the framework. Plus, lower weight than galv and lees work than galv conduit drops from the trunking to the points. We can still use white plastic conduit but not sure how this would look. Not sure if this sounds nuts or overkill.
However, the installer decided to run in galv trunking. My thinking with this is that running singles in this means that the trunking could become live under fault conditions and will need bonding, etc.... With bonded trunking sat atop the metal panels fixed with metal screws (couldn't really use plastic for galv trunking) we are now bringing an earthy potential to the partitioning. I'll have to test but I'm not sure if the continuity of the panels is continuous. so, would this mean bonding the partitioning? It's not a short run either. the trunking comes in at 60mtrs for the entire perimeter!
Hope this makes sense. Am I waffling bollox, am I worrying over nothing or should we be doing something different?
Rutts
Rutts
